Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the ASUS ROG STRIX 750W at 45c. This makes Test #1 equal to 185W by loading the 12v rail to 13a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~160mV drop on the 12v rail and ~30mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~25mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the ASUS ROG STRIX 750W at 45c. This makes Test #2 equal to 343W by loading the 12v rail to 27a, the 5v rail to 4a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~160mV drop on the 12v rail and ~30mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~25mV drop.
The Transient Load Tests results for the ASUS ROG STRIX 750W are passing and excellent all around! In today’s testing, the ROG STRIX 750W saw the loaded 12v rail post a peak change of ~160mV, and the loaded 5v rail post a peak change of ~30mV. The unloaded 5v peak change during the 12v load was ~25mV. Those numbers are, in an absolute sense, outstanding! In a relative sense this unit was better than the Phanteks AMP 750 and EVGA SuperNOVA G5 750W. So, this is an excellent outstanding set of results for the ROG STRIX 750W today. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
