Silent hardware expert be quiet! has introduced a successor to its popular Shadow Rock Slim CPU cooler called the Shadow Rock Slim 2. The Shadow Rock Slim 2 is largely similar to its predecessor but features two notable improvements, a new optimized mounting kit for easier installation in alignment with the airflow and the addition of Heat pipe Direct Touch (HDT) technology for its four high-performance 6 mm heat pipes. The cooling capacity of the Shadow Rock Slim 2 is 160 W just like the older model, and the silence-optimized 135 mm fan that the Shadow Rock Slim 2 leverages offers the same level of 23.7 dB(A) noise at 100 percent operation as well.
| Model | Shadow Rock Slim 2 |
| Overall dimensions without mounting material (L x W x H), (mm) | 74 x 137 x 161 |
| Total weight (kg) | 0.69 |
| TDP (W) | 160 |
| Socket compatibility AMD | AM4 / AM3(+) |
| Socket compatibility Intel | 1200 / 2066 / 1150 / 1151 / 1155 / 2011(-3) Square ILM |
| Fan model, number | 1x silence-optimized be quiet! fan |
| Decoupled fan mounting | – |
| Overall noise level (dB(A)) @ 50/75/100% (rpm) | 11.5 / 18.7 / 23.7 |
be quiet! Shadow Rock Slim 2 is the space saving CPU cooler for gaming, multimedia and graphics-intensive compact PCs. With high performance, the famously silent be quiet! operation and an unmatched price-performance ratio, Shadow Rock Slim 2 is a best choice in this category.
Source: be quiet!
