Far Cry fans have a lot to look forward to next month, as the sixth mainline installment of the popular open-world shooter franchise, Far Cry 6, will be launching on October 7.
Ubisoft revealed the PC specifications for Far Cry 6 today to clarify what kind of hardware is needed to enjoy the game at higher resolutions and frame rates with ray tracing enabled.
Far Cry 6 players who wish to play the game at 1440p at 60 FPS with ray tracing will need an AMD Ryzen 5 5600X or Intel i5-10600 processor and AMD Radeon RX 6900 XT or NVIDIA GeForce RTX 3070 graphics card.
Those who wish to play the game at 4K at 30 FPS with ray tracing on will need an AMD Ryzen 7 5800X or Intel i7-10700K processor and AMD Radeon RX 6800 or NVIDIA GeForce RTX 3080 graphics card.
Far Cry 6 players should be able to get away with 8 GB of memory on lower settings (e.g., 1080p at 30 FPS), but 16 GB of memory is recommended for the ideal experience. The game will also require 60 GB of storage (SSD recommended), plus 37 GB for players who wish to use HD textures.
Minimum PC Settings
1080p, 30 FPS, DirectX Raytracing Off
- CPU: AMD Ryzen 3 1200 – 3.1 GHZ or Intel i5-4460 – 3.2 GHZ
- GPU: AMD RX 460 – 4 GB or NVIDIA GTX 960 – 4 GB
- RAM: 8 GB (Dual-channel mode)
- Storage: 60 GB HDD (SSD Recommended)
Recommended PC Settings
1080p, 60 FPS, DirectX Raytracing Off
- CPU: AMD Ryzen 5 3600X – 3.8 GHZ or Intel i7-7700 – 3.6 GHZ
- GPU: AMD RX VEGA64 – 8 GB or NVIDIA GTX 1080 – 8 GB
- RAM: 16 GB (Dual-channel mode)
1440p, 60 FPS, DirectX Raytracing Off
- CPU: AMD Ryzen 5 3600X – 3.8 GHZ or Intel i7-9700 – 3.6 GHZ
- GPU: AMD RX 5700XT – 8 GB or NVIDIA RTX 2070 SUPER – 8 GB
- Storage: 60 GB HDD (SSD Recommended) + 37 GB for HD textures (optional)
1440p, 60 FPS, DirectX Raytracing On
- CPU: AMD Ryzen 5 5600X – 3.7 GHZ or Intel i5-10600 – 4.1 GHZ
- GPU: AMD RX 6900XT – 16 BG or NVIDIA RTX 3070 – 8 GB
4K, 30 FPS, DirectX Raytracing On
- CPU: AMD Ryzen 7 5800X – 3.7 GHZ or Intel i7-10700k – 3.8 GHZ
- GPU: AMD RX 6800 – 16 GB or NVIDIA RTX 3080 – 10 GB
Additional Features:
- Uncapped framerate
- In-depth customization options
- Hybrid input and extended control customization
- Multi-monitor and widescreen support
- In-game benchmark for performance analysis
- DirectX Raytracing (DXR)
- AMD FidelityFX Super Resolution Support
In Far Cry 6, you will fight to liberate the island nation of Yara from its oppressive dictator, Antón Castillo. Ahead of the game’s October 7 launch, make sure your PC is ready by checking out the minimum and recommended PC settings. For all the settings listed below, make sure your PC is running Windows 10 (20H1 version or newer, 64-bit only), and that your system is compatible with DirectX 12 (DX12):
Source: Ubisoft
