Multiple instances of native ATX 3.0 12VHPWR connectors melting are now beginning to pop up across the internet. One of the first happened a couple of days ago when a user posted about their experience on their Facebook page. It has since been reposted, under different accounts, on Reddit multiple times but others are also coming forward with their own experiences. The original poster has also shared a video on Bilibli. They explained how an MSI Meg Ai1300P PSU was used with its own 12VHPWR connector and that excessive bending, or twisting, was not the cause and confirmed multiple times they left enough clearance during installation. The user, ironically, ended up switching to a 3x 8-pin adapter upon discovering the melted connector. NVIDIA has reportedly contacted this poster to return their card and PSU to them for further investigation.
Another user posted images of their ATX 3.0 12VHPWR connector but this time it was for an MSI MPG A1000G. They too stated that “The cable was not bent, twisted, or manhandled whilst installed.”
In reading replies to both of these posts, there are other users coming forward with their own reports, and those of the adapter continue to grow as well. NVIDIA has yet to comment on the matter but is presumably waiting until its own investigation, where it has asked its partners to collect all damaged cards, is completed. However, it now appears that NVIDIA may want to reach out to PSU manufacturers now that multiple instances of native ATX 3.0 12VHPWR connectors melting are now being reported and the adapters are no longer the only ones being reported on.
There have been numerous theories as to what is the ultimate culprit for these meting connectors but so far none have panned out to be fully confirmed. From bending or twisting to improper installation by not fully inserting the connectors, to different ratings being seen on various wires, possible soldering issues with the connectors, suggestions that the connector is not a good design fit for this use, and potential manufacturing defects, the list continues to grow. In terms of manufacturer defects, another user stated they’d had two pins pop out of their Thermaltake GF3 1650W 12VHPWR cable. They contacted Thermaltake who offered a full refund due to being out of stock but the user declined since the PSU actually has 2x 12VHPWR ports and cables so they were able to use the other.
Discussion (19 replies)
Join Discussion →I'm starting to not really buy into these instances with the melted connectors, and it's not just because I own a 4090. I want to see proof on how the card was installed with the cable(s) plugged into the card and how it looked installed with the cable before they pulled it out and checked the connector. I have a feeling that these "instances" are more on the user end than what is being told to the population. People are also blaming Nvidia for not coming out and addressing the issue, but how can they with such a small amount of cards having issues? Maybe just a generalized statement saying they are collecting data may suffice I guess. Some are also spectualting that other means are being used to melt the connector just because of buyers remorse. Not sure about that theory though myself. Just my opinion.
I was thinking about the installation process being a factor as well but it also got me thinking that aside from card dimensions the card manufacturers should also be putting disclaimers about how much more clearance from the card is required for the cable as well. I was looking at one picture (couldn't re-find it because I was really deep in Reddit this morning looking at different ones) and noticed the case side panel was fairly close to the card's power connector port. That can't be a good thing if users are expected to not bend it until after a certain length of the cable. These days most people are more focused on the length or height of a case than they are on the width.
The good news is that yes these numbers do seem to be low (maybe one or two dozen?), for now, and that no one has been injured. I do wonder though how many simply are not aware if any damage has happened, yet and so haven't reported on it.
Buyer's remorse is a possibility but considering how insanely good this card is I'd call them idiots if that was the cause. Even more so if they paid scalpers and have remorse for that.
I do agree though that user error could be the dominating factor here and that there's no proof saying otherwise, just people's word on what they said they did. However, if this thing really is that precarious is it really up to the user to be so careful when a previous design was all but foolproof?
Just to add that it is odd this could be happening with the cable and not the adapter. I would think that in the absence of the extra 8-pin connectors it would be easy to install without excessive bending. If people are giving it the angles/space it needs then there is more going on here. If they are obsessively bending it to hide as is common for many enthusiasts, that could easily be the root of it also.
Oh, here's the one I was talking about. For them it was a 3x 8-pin adapter.
[embedded media]
This I totally agree with. I don't believe they should have stayed with what worked.
That isn't ideal unless they do not put the side panel on the case. That looks like a Corsair 4000 or maybe a 5000 series case. My 7000 series case side panel hardly touches the cable.
Don't be like that. Just because it didn't happen to you doesn't mean it must be user error. These cards are huge, space in some cases is tight, so the cable will bend in different directions and strain will be put on different parts of it, not to mention the different quality cables going around by manufacturer.
The cable should hold up to a reasonable amount of strain. Even if this cable is fine 99.9% of the time but has problems for .1%, it is still a bad cable that is unsuitable for the application.
For example splicing a bare wire into a molex connector also works most of the time, yet it would not be an acceptable solution out of the factory.
The Cablemod right angle adapter should solve most of these issues, but for some reason is till MIA. I signed up to be notified, and so far got to select the kind I need, but no way to order one. I do have the "normal" cable coming from them as well to use with my EVGA PSU. I did order an ATX 3.0 FSP power supply that is on its way, but torn between using that or the Cablemod cable for my existing power supply.
Be like what? Honest? State my opinion? Yeah how dare I do that. Like I said it's my opinion so I'll leave it as that. Not sticking up for Nvidia, and I agree it's a poor design overall, but user error cannot be dismissed.
I'm glad for any who do not have to deal with this issue but I really feel NV needs to come up with a better solution. For the most part, nobody is saying it's the board or PSU connectors and it repeatedly seems to be coming back to cables now. Perhaps they offer to ship a right-angle adapter? Maybe something similar to EVGA's? I don't know but it's ridiculous that users were not warned ahead of time that cable clearance would be such an issue.
I didn't post it but did come across a Reddit post from Cablemod saying the pre-order registration thing got messed up. It was buried in one of the reply threads I was in and I don't remember where. Evidently, it's about 4-5 weeks out before they'll begin to receive them. I also registered but never heard anything.
Meanwhile, some are saying good things about this: https://www.fasgear.com/ and https://www.amazon.co.uk/dp/B0B7MGTY56/ref=cm_sw_r_apa_i_7N7JTEPN39P12BPHTV6M_0?_encoding=UTF8&th=1
I've never heard of them before so I don't know about them either but some in those threads are saying good things but I did see one review on Amazon that said it didn't work for them, but 30 that did and gave praise.
Don't assume user error. If I have tight space in my case and as such I have to put more strain on the cable that's not user error. I can reasonably expect the cable to still function, just as my PCIE 8 pin connectors don't fail in tight spaces.
This is an unforseeable error, so you don't need to defend your purchase decision. I'd have assumed NV put utmost effort into these adapters to make sure they work fine, because most of us were against using them from the start. NV dropped the ball bigtime.
The PCiE connectors almost have too much of a safety margin, while these apparently have zero.
If its this sensitive, its inadequate, its that simple.
Nvidia didn't want a big fat connector, didn't want tons of little ones either, it was clearly to me an optics over engineering choice. Not to worry, they'll be forgiven in no time.... But lets remember AMD drivers they crashed back in 2015 so I never touched an AMD card again.
The 4090 must be doing something different with power vs the 3090, if power overall is the same either it is spiking higher, or overloading a pin or 2 more than the rest. Can't be that everyone had perfect installations with the 3090,/with perfect cables. Also, these are failures of the most niche product in existance, so that divider in the equation is relatively small, and really will remain small.
While you got a point, but my AMD card's drivers were crashing last year when I owned a 5700 XT. Just sayin'
Defending my purchase is not something I have ever done and I'm not doing that here. I agree that things could have been done better with the connector, but nothing has been proven that anyone dropped the ball. I guess time will tell.
AMD has never been my go to for cards. Back when they were ATI I used them more. Had a few non driver issues with them (though their drivers weren't great either), and I just didn't look at them any longer. When ATI existed and Omega drivers were a thing those were fun times.
