Thermaltake Unveils CYCLEDESK 100 Smart Gaming Desk
Image: Thermaltake
Thermaltake has unveiled the CYCLEDESK 100, a new gaming desk that’s designed not only for gaming and working, but also for professional cycling esports. Supported by a TT Smart Control Unit that allows users to control the desk’s height directly or via phone or PC via WiFi, the desk features four levels of programmable desk heights, a small footprint, and four wheels with rotating and lockable casters, making it extremely mobile. Thermaltake did not provide pricing details for the CYCLEDESK 100 in its press release or landing page.
  • Great for cycling esports, works, and games
    • CYCLEDESK 100 is a professional bike training desk and can be height-adjusted effortlessly. Its small footprint makes it possible to be pushed around, thereby being extremely mobile. It’s great for a majority of use cases, including cycling esports, workplaces, and gaming.
  • TT Smart Control Unit
    • TT Smart Control Box is the heart of the CYCLEDESK 100, making it not only a desk but smarter than you think. With this small box, you can control your desk directly and stably on your phone or PC via WiFi. Also, the powerful MCU can remember your desk settings and usage habits, and will automatically adjust your desk according to your needs.
  • Exclusive RGB Desk Mobile App
    • Through RGB Desk Mobile APP, desk height can smoothly be set from 72 cm to 117 cm and switched between 4 levels of programmable desk heights. Besides, your settings will be recorded, and adjusted your desk height according to your schedule. On top of that, 4 different lighting effects, 5 brightness levels, and lighting speed can all be tweaked until you’re satisfied.
  • iTkae Engine Software
    • Through iTAKE Engine Software, you can easily set the desk height from 72 cm to 117 cm (28.3″ ~ 46″). To take things one step further, you can choose between 4 different lighting effect settings with 5 brightness levels and lighting speed.
  • Record All Your Usage
    • CYCLEDESK 100 will automatically adjust desk height according to your schedule and usage habits.
  • RGB Lighting Strip
    • The CYCLEDESK 100 Smart Gaming Desk comes with an RGB Lighting Strip. Customize, control and sync lighting effects via the Thermaltake RGB desk mobile app or iTAKE engine software. Take it a step further and choose between 4 different lighting effect settings coupled with 5 individual levels of brightness and lighting speed.
  • 6-Button Easy Access Panel
    • Utilizes a 6-button controller for easy operations along with a digital display board that shows accurate height adjustments. The smart controller panel can set up to 4 height memory settings, so users can store and conveniently switch to their desired height setting with a push of a button.
  • Stable Motor
    • The upgraded electric motor offers the desk a stable process when adjusting the height.
  • Anti-collision Safety Sensor
    • For your safety, we’ve included an anti-collision safety sensor to automatically detect when the desk encounters obstacles while elevating your gaming desk.
  • Excellent Mobility with Four Wheels
    • Designed with four 360° rotating and lockable casters that enable you to roll this desk to everywhere you like.
  • Full-Size Laptop Stand
    • Cradle up your devices vertically, and build up a neat and organized space for your desk.
  • Cable-management System
    • Easy and convenient to sort out your cable for keeping your workspace clutter-free.
  • Waterproof Mouse Pad
    • High-density physical cloth waterproof surface. In daily use, if water or beverages are sprinkled on the mouse pad, small water droplets will form, which are not easy to penetrate.
Image: Thermaltake
From a Thermaltake press release:
CYCLEDESK 100 looks nothing like your everyday desk. Its small footprint and mobility allow it to fit into the majority of environments and will change your preconception about a desk. CYCLEDESK 100 is designed with three main use cases in mind, professional cycling esports, working, and gaming. To elaborate, when using CYCLEDESK 100 for cycling esports, you can have your PC monitor or laptop set up on the desk to watch the contents you enjoy. In terms of working and gaming, to ensure all-day comfort, desk height can be easily adjusted to meet your needs. Plus, with the wheels installed, moving around your house is no longer an issue anymore.
Empowered by TT Smart Control Unit, CYCELDESK 100 can be height-adjusted through your mobile devices via WiFi or PC. Besides, 16.8 million RGB lighting colors and effects can be tweaked from the comfort of your fingertips. What’s more, your usage and height settings will be recorded, and therefore adjust desk heights according to your schedule. Lastly, with RGB Desk Mobile APP, an exclusive app for CYCLEDESK 100 available on Android and iOS, it is more than intuitive for you to switch between 4 preset desk heights from 72cm, 90cm, 100cm, to 117cm. In addition, lighting effects, frequencies, and brightness can also be tweaked effortlessly. On the other hand, with iTake Engine Software, also an exclusive app available on Android and iOS, enables users to switch between preset desk heights and lighting mentioned above, and it allows desk height to be set from anywhere between 72 cm to 117 cm (28.3″ ~ 46″).
We make it even easier to work with CYCLEDESK 100, users get to ascend, descend, and set as preset with a push of a button on the front panel. There’s also a display showing exactly your current desk height. As for its build quality, we have implemented upgraded electric motors for a far smoother adjusting experience. Aside from that, safety is what we value the most. CYCLEDESK 100 will automatically stop once touching the surface of unwanted objects thanks to the anti-collision safety sensor installed. More little details and features include the ability to move with four 360° rotating and lockable casters, a side laptop stand for organized desk space, a cable management system for a clutter-free user experience, and a waterproof mouse pad to keep the surface clean at all times.
CYCLEDESK 100, with its versatility being able to run in a wide array of use cases such as cycling esports, workspaces, and gaming, can not only fit in any environment you put in but provide the best ergonomics and user experience, period. CYCLEDESK 100 is second to none in terms of multi-purpose desks and is your go-to option for cycling esports, works, games, and more.
