Cooler Master has launched the TD500 Mesh V2, an upgrade to one of the company’s most well-loved case designs that maintains the original’s intricate geometric design but introduces various enhancements, including thicker radiator compatibility, USB 3.2 Gen 2 Type C connectivity, and a PSU shroud that can be removed for users who would prefer to keep their power supplies hidden. The TD500 Mesh V2 will be available for US$89.99 MSRP in Black and White color options.
TD500 Mesh V2 Highlights
- Available in Black or White
- Polygonal Mesh Front Panel featuring a three-dimensional contour providing high airflow and dust filtration
- Three pre-installed 120mm ARGB fans
- Support for up to seven 120mm fans. 360mm front and top radiator support
- Tool-less crystalline designed side panel for quick access
- PSU shroud with removable cover and removable Top Panel for improved access
From a Cooler Master press release:
The TD series has been one of Cooler Master’s most successful case series since launch. Most notable for its unique three dimensional front panel paired with 120mm ARGB fans, TD cases yield an ever-changing light effect that shifts based on the angle viewed. Diamond cut etchings spans across the surface of the tempered glass side panel, enhancing the geometric theme. The TD500 Mesh V2 not only preserves this one-of-a-kind design, but also enhances the chassis’ functional features, including thicker radiator compatibility for unbeatable thermal performance. USB 3.2 Gen 2 Type C connectivity has been added to empower lightning fast transfer speeds, as well as repositionable PSU shroud cover so users can freely decide whether they would like to showcase their PSU.
- Polygonal Mesh – Crafted from Cooler Master’s Fine Mesh technology, Polygonal Mesh features a three-dimensional contour and is also capable of simultaneously providing high airflow and dust filtration.
- Triple ARGB Fans – Three addressable RGB fans flood the Polygonal Mesh front panel with lighting while providing considerable airflow to the system.
- USB 3.2 Gen 2 Type C Support – USB 3.2 Gen 2 Type C port built into the I/O panel allows multi-purpose, streamlined data transmission.
- Versatile Cooling Options – Support for up to seven 120mm fans and 360mm front and top radiator support ensure that performance is not compromised.
- Tool-Free Crystalline TG Side Panel – A crystalline design spans the edges of the tempered glass side panel, completely toolless for quick access to the internals. An optional screw can be installed to further secure the tempered glass side panel.PSU Shroud With Removable Cover – TD500 Mesh V2’s removable PSU cover allows users to freely showcase unique PSU designs or keep PSUs hidden for a stealthier aesthetic. When not in use, the PSU cover can be stored on the motherboard tray for easy safekeeping.
- Removable Top Panel – The top panel is entirely removable for improved access to the components during assembly. Ease of use also facilitates the mounting of cooling solutions such as fans and radiators.
