GIGABYTE Launches 1,300-Watt UD1300GM PCIe 5.0 ATX 3.0 Power Supply
GIGABYTE has announced the UD1300GM, a new 13,000-watt power supply with 80 PLUS Gold certification that fully supports the latest PCIe Gen 5.0 and ATX 3.0 standards. Capable of providing up to 600 watts of power to NVIDIA GeForce RTX 40 Series graphics cards through a high-quality 16-pin cable, the leading manufacturer of premium gaming hardware also noted that the PSU can sustain up to two times total power excursion, having been designed in compliance with the ATX 3.0 standard. Complementing the UD1300GM are revised versions of the UD1000GM and UD850GM, which feature output capacities of 1,000 and 850 watts, respectively.
GIGABYTE UD1300GM Key Features
  • Ultra Durable
  • Main Japanese capacitors
  • Enhanced thermal solution
  • 140mm smart hydraulic bearing (HYB) fan
  • OVP/OPP/SCP/UVP/OCP/OTP protection
  • Support PCIe Gen 5.0 graphics card
  • Support Intel ATX 3.0 standard
  • 80 PLUS Gold certified
  • Fully modular design
  • Compact size
  • 10 years warranty (Adjusted according to different regions)
From a GIGABYTE press release:
The UD1300GM PCIE 5.0 power supply fully supports the PCIe Gen 5.0 and ATX 3.0 standard. Traditional power supplies need multiple 8-pin to 16-pin adapters to support the latest PCIe Gen 5.0 graphics cards. The new UD1300GM PCIE 5.0 power supply needs only a single 16-pin cable to directly supply power to the PCIe Gen 5.0 graphics card. The 16-pin cable provides up to 600 watts of power to the graphics card. Reducing the number of cables makes the installation of the graphics card more convenient and safer, making the interior minimalistic and appealing, and improving the airflow inside the chassis. The UD1300GM PCIE 5.0 power supply is fully compatible with Intel PSDG (Power Supply Design Guide) ATX 3.0 standard which supports up to 200% power excursion, reaches 70% low load efficiency and complies with required power supply timing standards.
The UD1300GM PCIE 5.0 power supply inherits the spirit of GIGABYTE Ultra Durable product design, introducing a variety of high-quality materials and designs. Ultra Durable design combines high-quality main Japanese capacitors, enhanced thermal solution, 140mm smart hydraulic bearing (HYB) fan, and OVP/OPP/SCP/UVP/OCP/OTP six circuit protection designs. Moreover, it provides users with high-quality and stable power delivery, and it can be used for a long time. In addition, the UD1300GM PCIE 5.0 power supply also features 80 PLUS Gold certification, fully modular design and compact design. It is the best choice for high-end gamers and overclockers.
GIGABYTE continuously releases new power supplies that support the latest PCIe Gen 5.0 and ATX 3.0 standard. Customers have options of not only 1300W but also 1000W (UD1000GM PCIE 5.0 rev.2.0) and 850W (UD850GM PCIE 5.0 rev.2.0). They can choose the corresponding wattage based on their system requirements to fully unleash the performance of the GeForce RTX 40 series graphics card. The UD series power supplies not only provide high-quality power supply but also consider long-term safety and stability for a secure and enjoyable high-quality gaming experience. They are the best partners for the latest graphics cards.
