GIGABYTE Launches AMD Radeon RX 7600 GAMING OC 8G Graphics Card with 2,755 MHz Boost Clock and WINDFORCE Cooling System
Image: GIGABYTE
GIGABYTE has launched its first AMD Radeon RX 7600 graphics card in the form of the Radeon RX 7600 GAMING OC 8G. Equipped with GIGABYTE’s flagship WINDFORCE cooling system, which is said to provide unprecedented performance, visual effects, and efficiency for 1080p gaming and streaming experiences, the Radeon RX 7600 GAMING OC 8G features a game clock of up to 2,355 MHz and a boost clock of up to 2,755 MHz, 100 MHz faster than the reference model’s specification. GIGABYTE didn’t share pricing in its press release, but AMD has given the Radeon RX 7600 an SEP of $269, with availability starting May 25.
GIGABYTE AMD Radeon RX 7600 GAMING OC 8G Features
  • Powered by Radeon RX 7600
  • Integrated with 8GB GDDR6 128-bit memory interface
  • WINDFORCE cooling system
  • RGB Fusion
  • Protection metal back plate
  • Boost Clock: up to 2755 MHz (Reference card: 2655 MHz)
  • Game Clock: up to 2355 MHz (Reference card: 2250 MHz)
From a GIGABYTE press release:
The GIGABYTE WINDFORCE cooling system is specifically designed for gamers. It features three unique blade fans with alternate spinning, composite copper heat pipes in direct contact with the GPU, 3D active fans and screen cooling that work together to provide efficient heat dissipation. The Alternate Spinning technology rotates the central fan in the opposite direction of the side fans, directing airflow in the same direction and doubling air pressure while reducing turbulence. This effectively dissipates heat from both the top and the bottom of the graphics card, resulting in improved overall cooling performance.
The WINDFORCE fans utilize graphene nano lubricant, which can extend fan life by 2.1 times, delivering nearly the lifespan of the double ball bearing while providing quiet operation. The protective back plate not only strengthens the overall structure of the graphics card, but it prevents the PCB from bending or sustaining damage. The graphics card features a gaming-style design with LED lighting on the side that can be customized through software to display a personalized style.
The excellent performance of the graphics card is due to its power design and the use of ULTRA DURABLE certified components. The Ultra Durable certified high-quality materials such as all-solid capacitors, metal chokes, and low-resistance MOSFETs provide excellent computational performance and longer lifespan, allowing gamers to fully immerse themselves in 1080p gaming and experience vivid virtual worlds.
In addition, the AMD Radiance Display Engine provides superior color accuracy, while AMD FidelityFX Super Resolution and Radeon Super Resolution upscaling technologies boost frame rates while delivering crisp, high-resolution image quality, making the GIGABYTE Radeon RX 7600 GAMING OC 8G graphics card the top choice for entry enthusiast gamers.
Image: GIGABYTE
Image: GIGABYTE
