Synthetic System Benchmarks – Ryzen 5 7600
We are going to start with synthetic system application benchmarks on this page. Note that the graphs are arranged from fastest to slowest. We have also highlighted the Ryzen 5 7600 and Ryzen 5 7600 with PBO ENABLED to give you a better visual comparison to the Ryzen 5 7600X. The label “PBO ENABLED” indicates the Ryzen 5 7600 with PBO ENABLED in the BIOS.
PCMark 10
PCMark 10 Express
AMD Ryzen 5 7600 CPU PCMark 10 Express
Our goal today is to find out the difference in performance between the Ryzen 5 7600 and Ryzen 5 7600X. In addition, we want to see how turning on PBO affects performance and if the Ryzen 5 7600 can come close to Ryzen 5 7600X performance with the automatic overclocking.
Starting off in PCMark 10’s Express system benchmark, we find that the Ryzen 5 7600 is only about 4% slower than the Ryzen 5 7600X in PCMark 10’s express benchmark. This benchmark focuses mainly on more lightly threaded office application types of workloads. In this scenario, you don’t have a big difference between the CPUs for performance. Adding PBO did not provide this system test with a lot of performance, about 0.3% performance gain.
Geekbench 6
AMD Ryzen 5 7600 CPU Geekbench 6
In Geekbench 6 Multi-Core performance we are now looking at multi-core performance, where the benchmark pushes all the cores harder. The Ryzen 5 7600 is now 5% slower than the Ryzen 5 7600X. Therefore when all cores are being used, we see a greater hit on performance, since it runs at a lower frequency, but it’s still only 5% in total. Turning on PBO helped claw back a little performance by 1%.
In Geekbench 6’s single-thread performance, we find that the Ryzen 5 7600 is 6% slower than the Ryzen 5 7600X, which is greater than the multi-core performance. The clock speed likely is not near the 7600X. Enabling PBO did not help much, and added only 0.4% performance to the 7600.
3DMark CPU Profile
AMD Ryzen 5 7600 CPU 3DMark 10 CPU Profile
In 3DMark’s CPU Profile test, we are running the “Max Threads” test and looking at overall performance. This benchmark really shows the difference between the CPUs in maximum thread performance. The Ryzen 5 7600 is now 7% slower, overall, compared to the Ryzen 5 7600X. As you can see, as more threads are used, and more cores, the difference can widen to a difference that is noticeable. Enabling PBO claws back more performance, adding 3% more performance, and coming closer to the 7600X.
When it comes to single-thread performance though, we find the Ryzen 5 7600 is 6% slower than the Ryzen 5 7600X. Again, frequency is the key point here. PBO does not help performance in single-core performance for the most part.
Performance
Efficiency (Perf per Watt)
