MSI MAG B760 TOMAHAWK WIFI Motherboard Review
CPU Frequency, Power, and Temperatures
MSI MAG B760 Tomahawk WiFi CPU power graph.
The CPU power results are exactly what we expected. Using Intel defaults, the power limit is supposed to be around 241w give or take. When using MSI’s power limits, we see a relatively small increase in power consumption. However, we do not get a performance uplift much or if at all. However, this is partly because we are more or less at the limit of the AIO cooling used for our testing here.
MSI MAG B760 Tomahawk WiFi CPU temperature graph.
As you can see, the temperature maximums were identical between MSI and Intel’s power settings. As a result, we can’t really get any more performance for our increased power limits as we are effectively limited by our cooling.
MSI MAG B760 Tomahawk WiFi CPU clock speed graph 1.
When looking at average CPU clocks, we can see broadly similar averages using the two power profiles. Again, I think this comes down to the limitations of our cooling. With more cooling, we might see some increase in clocks. This isn’t an issue with the MSI board either as I’ve broadly seen the same results from this CPU on multiple motherboards at this point.
MSI MAG B760 Tomahawk WiFi CPU clock speed graph 2.
In contrast, our maximum clocks are pretty good but unfortunately, MSI’s power limit increase doesn’t net us much here either. Only about 25MHz which as we saw in the benchmarks didn’t help or even hurt performance in some cases.
6
Motherboard Layout
Performance & Stability
Price Value
The MSI MAG B760 TOMAHAWK WIFI is solidly built and has decent VRM's for the price but falls short with its budget audio and wired networking controllers. Its layout on the other hand is nearly perfect and it was the pinnacle of stability during testing with no lockups, crashes, or odd behavior during testing. At $180, the MSI MAG B760 TOMAHAWK WIFI has a lot to offer.
Dan Dobrowolski
