MSI GeForce RTX 4070 Ti GAMING SLIM 12G Video Card Review
Test Setup
Please read the information on our GPU testing procedures and methodology here.  Note that our GPU Testing Bench has been upgraded to the Ryzen 7 7800X3D CPU and AM5 platform.
Note that we have the 1807 BIOS installed, which uses AGESA version Combo AM5 PI 1.1.0.1. We are using the motherboard’s current default BIOS settings on the latest release BIOS. We have enabled PCI-Express Resizable BAR in the motherboard BIOS.  This means we are utilizing Resizable BAR on NVIDIA GPUs and AMD Smart Access Memory on AMD GPUs in all our testing.  We have enabled EXPO I in the BIOS for the memory.
We are using a fresh install of Windows 11 Pro with the latest Windows Updates, including the 23H2 Fall 2023 update. We have the latest drivers installed including the latest chipset drivers from AMD.  We are using the “Balanced” power profile in Windows Settings.  Hardware Accelerated GPU Scheduling is ENABLED in Windows.  VBS is DISABLED and Game Mode is ENABLED.
Power Efficiency
Build and Cooling
Price Value
7
We reviewed the MSI GeForce RTX 4070 Ti GAMING SLIM 12G Video Card, a new thinner, smaller configuration of the MSI GeForce RTX 4070 Ti GAMING TRIO. This one is able to maintain its performance, and isn't constrained by the smaller build, and provides GPU boost performance and overclocking headroom as well. The cooler works really well, and the GPU is very efficient. Its gaming performance trails the Radeon RX 7900 XT, and pricing will be an important factor. The non-X variant should be less money than the overclocked model, and still has the ability to overclock very well.
