Noctua has announced the availability of two new products today: (1) the NF-A6x1, a “highly optimized, premium-quality” quiet fan in size 60×15 mm that is available in 12V and 5V variants, both with 3-pin and PWM 4-pin connectors, and (2) the NA-SC1 Sx2, a set of three-way PWM splitter cables for running three fans off of a single fan header. Here are some additional product shots and a portion of the press release from Noctua, which includes pricing information and notes their availability via Noctua’s official Amazon stores:
The manufacturer’s suggested retail prices are as follows:
NF-A6x15 PWM: EUR 16.90 / USD 14.90
NF-A6x15 FLX: EUR 16.90 / USD 14.90
NF-A6x15 5V PWM: EUR 16.90 / USD 14.90
NF-A6x15 5V: EUR 16.90 / USD 14.90
NA-SC1 Sx2: EUR 9.90 / USD 9.90
Featuring advanced aerodynamic design measures such as Flow Acceleration Channels and Noctua’s AAO frame, the NF-A6x15 is a highly optimised, premium-quality quiet fan in size 60x15mm. It is available in 12V and 5V versions, both with 3-pin and 4-pin (PWM ) connectors. The 5V versions include Noctua’s OmniJoin adaptor set for easy connection when replacing fans with custom headers as well as a USB-A power adaptor cable that allows running them on power banks, devices with USB host ports or USB power supplies.
The NA-SC1 Sx2 is a set of two NA-SC1 3-way PWM fan splitter cables that make it possible to power and control three fans through one fan header. By connecting the second triple splitter cable to the first, a total of five fans can be powered and controlled simultaneously. Thanks to the high-quality black fibreglass silicone sleeving, the NA-SC1 cables are ideal both for use in PCs and for home or multi-purpose ventilation applications.
Discussion (2 replies)
Join Discussion →Hmm. Did they not have 60mm fans before? I can't remember.
That is certainly a less common size, at least these days.
Where 120mm fans don't fit, most systems use 80mm. Some coolers 92mm. Smaller routers, switches and other 1U stuff fit 40mm fans, but I don't see a lot of 60mm.
These are thinner; they already have 60mm x 25mm fans.
