ASRock Redefines Performance with AMD Radeon RX 9070 XT and Radeon RX 9070 Taichi, Steel Legend, and Challenger Graphics Cards
Image: ASRock
(PR) ASRock, the leading global motherboard, graphics card and mini PC manufacturer, today launched the new Taichi, Steel Legend and Challenger series graphics cards based on AMD Radeon™ RX 9070 XT and Radeon™ RX 9070 GPUs.
The new graphics cards are built-in the ultra-fast AMD RDNA™ 4 architecture graphics which features 3rd Gen raytracing and 2nd Gen AI accelerators to deliver the performance you need to max out your gaming. Powered by AMD RDNA™ 4 architecture, the AMD Radeon™ RX 9070 XT GPU features 64 compute units (3rd Gen raytracing and 2nd Gen AI accelerators), AMD HYPR-RX, AMD FidelityFX™ Super Resolution, DisplayPort™ 2.1, and PCI Express 5.0 ready. And the AMD Radeon™ RX 9070 features 56 compute units (3rd Gen raytracing and 2nd Gen AI accelerators), AMD HYPR-RX, AMD FidelityFX™ Super Resolution, DisplayPort™ 2.1, and PCI Express 5.0 ready.
The AMD RDNA™ 4 architecture also delivers various features such as Radiance Display™ Engine, Fluid Motion Frames 2 technology*, Radeon™ Anti-Lag 2 technology, AV1 Encode/Decode*, AMD FidelityFX™ technologies* and AMD Noise Suppression etc. These rich features enhance the gaming comprehensive performance of RDNA 4 and bring much powerful gaming platform to gaming users.
ASRock AMD Radeon™ RX 9070 XT Taichi 16GB OC Graphics Card
With factory pre-overclocking, the ASRock AMD Radeon™ RX 9070 XT Taichi 16GB OC graphic card achieve the highest 3100 MHz during the RX 9070 XT OC settings. The high-end, 3-slot Radeon™ RX 9070 XT Taichi 16GB OC is using the triple-fan Taichi 3X cooling system with the customized 100/100/100mm Striped Ring Fans, Air Deflecting Fin and Ultra-fit Heatpipe, greatly increasing thermal efficiency. The reversion spins design allows the center fan spins reversely to lower turbulence and enhance air dispersion through the heatsink. The unique ARGB on the front cover and side LED lighting effects support Polychrome SYNC allowing users to customize lighting effects. They are also equipped with up to 16 power phases design with SPS to offer enhanced performance. The metal frame and backplate prevent the PCB from bending, and the Dual BIOS option allows users to freely choose their favorite BIOS settings to optimize for performance or quiet operation. With its excellent performance and rich features, ASRock’s Radeon™ RX 9070 XT Taichi 16GB OC graphics card is the premium choice for power users.
Image: ASRock
ASRock AMD Radeon™ RX 9070 XT Steel Legend 16GB Graphics Card
ASRock AMD Radeon™ RX 9070 Steel Legend 16GB OC Graphics Card
The brand new design Steel Legend series graphics cards bring different outlook with the elegant decoration in white and gray colors. The ASRock AMD Radeon™ RX 9070 XT Steel Legend 16GB and ASRock AMD Radeon RX 9070 Steel Legend 16GB OC graphics cards for white-themed PC builders achieve a Boost Clock of up to 2970 MHz and 2700 MHz. The triple thermal design with the unique Striped Ring Fans, Air Deflecting Fin and Ultra-fit Heatpipe provide excellent heat dissipation. The metal frame and metal backplate strengthens the structure and prevents the plate from bending. The ARGB fans combined with Polychrome SYNC software allows users to customize and control the lighting effects. These useful features and unique white/gray camouflage design make the ASRock AMD Radeon™ RX 9070 XT Steel Legend 16GB and ASRock AMD Radeon™ RX 9070 Steel Legend 16GB OC graphics cards the premium choices for white PC builders.
Image: ASRock
Image: ASRock
ASRock AMD Radeon™ RX 9070 Challenger 16GB Graphics Card
The mainstream ASRock AMD Radeon™ RX 9070 Challenger 16GB graphics card offers a Boost Clock of up to 2520 MHz. This newly-designed stylish Challenger triple-fan cooler, the exclusive Striped Axial Fan, and Ultra-fit Heatpipe to provide efficient heat dissipation. The multi-color LED indicator makes the graphics cards more eye-catching. The metal backplate strengthens the structure. The high-quality Super Alloy Graphics Card components provide more stable operation. These practical designs enable the ASRock AMD Radeon™ RX 9070 Challenger 16GB graphics card to be essentials of system integrators and mainstream users.
Image: ASRock
Product Links
AMD Radeon RX 9070 XT Taichi 16GB OC
https://www.asrock.com/Graphics-Card/AMD/Radeon RX 9070 XT Taichi 16GB OC/index.asp
AMD Radeon RX 9070 XT Steel Legend 16GB
https://www.asrock.com/Graphics-Card/AMD/Radeon RX 9070 XT Steel Legend 16GB/index.asp
https://www.asrock.com/Graphics-Card/AMD/Radeon RX 9070 Steel Legend 16GB OC/index.asp
AMD Radeon RX 9070 Challenger 16GB
https://www.asrock.com/Graphics-Card/AMD/Radeon RX 9070 Challenger 16GB/index.asp
