Capcom’s long-gestating sci-fi action game Pragmata launches Friday, April 17, and the pre-release performance data landing today paints a familiar picture for anyone who has played a recent RE Engine title: the game looks spectacular and runs better than it has any right to.
TechPowerUp published its full Pragmata Performance Benchmark Review yesterday, testing over 30 GPUs across multiple resolutions — a useful spread heading into launch week. Early reviews already dropping from outlets like TheSixthAxis are calling it one of Capcom’s best new IPs in years.
On the PC side, the RE Engine continues to be one of the best-optimized engines in the industry. Path tracing is supported with DLSS 4 and Ray Reconstruction — the same implementation used in Resident Evil: Requiem — and early benchmark data from DSOGaming shows the full path-traced mode at native 4K running at roughly 29-31 FPS on an RTX 5090, which is the expected cost of uncompromised physically based lighting on a lunar base setting with extreme contrast ranges. That’s a demanding workload for the planet’s current fastest consumer GPU, and it illustrates both how technically ambitious the rendering is and why DLSS 4 with Multi Frame Generation is essentially mandatory for playable frame rates in path trace mode.
Switch path tracing off, however, and the picture changes substantially. The game’s demo last year ran buttery smooth on mid-range hardware: a GTX 1660 Ti delivered stable triple-digit frame rates at 1080p, and an RTX 3070 handled 1440p at the highest quality preset without compromise. Capcom has once again delivered a title that scales from budget cards all the way up to high-end silicon without requiring players to compromise significantly on image quality at either end.
The game ships with Denuvo DRM, which some players are noting ahead of launch, particularly those on lower-end CPUs who have historically seen minor performance friction from certain Denuvo implementations. Capcom’s recent track record with Denuvo has been relatively clean, and with the RE Engine’s CPU efficiency being well established, it is unlikely to be a significant issue for most. Still worth flagging for anyone running an older platform.
Pragmata is available on PC, PS5, Xbox Series X/S, and Nintendo Switch 2. For PC players with a capable rig, the path tracing mode looks genuinely stunning in early footage — the lunar base setting’s harsh vacuum lighting and reflective surfaces are exactly the kind of scene where physically based rendering makes the biggest visible difference. The full benchmark piece on TechPowerUp is worth a read before you pull the trigger Friday.
Discussion (3 replies)
Join Discussion →Wow thats awesome to see.
The tech power up article only has the 5090 numbers. Was hoping to see how AMD cards do. Sigh...
Other cards should return on Thursday to that review. Apparently there was an embargo condition added Friday and nobody told them they could only use one card....
The good news is that RE Engine has often favored AMD cards in past years. It wasn't until RE Requiem that we truly started to see greater support for NV features so I'd be shocked if the AMD GPUs don't perform well with this.
