MSI has made available two new models to its gaming monitor lineup with the addition of the MPG 322UR and MAG 321UP QD-OLED X24 displays. While there may not be anything exciting regarding new GPUs thus far in 2026, the year is looking to be promising when it comes to new gaming monitors. With 4th-gen QD-OLED panels arriving in 31.5-inch sizes, those wanting to expand beyond the never-ending amount of 24 and 27-inch offerings are finally getting some alternative choices. Both panels are VESA DisplayHDR True Black 500 certified and rated for 97% Adobe RGB, 99% DCI-P3, 138% sRGB color coverage and a contrast ratio of 1,500,000:1.
“Experience immersive gaming with the MAG 321UP QD-OLED X24. Featuring a 3840 x 2160 (UHD) QD-OLED panel, 240Hz refresh rate, and 0.03ms (GtG) response time, it delivers stunning clarity and speed. VESA ClearMR 13000 and DisplayHDR True Black 500 ensure vivid visuals with deep blacks and minimal motion blur.”
-MSI
First up, we have the MSI MAG 321UP QD-OLED X24 with a 4th-GEN Tandem QD OLED panel. MSI has coated the display with its DarkArmor Film for deeper blacks and added scratch protection. The 31.5-inch 4K display has a peak HDR luminance of 1000-nits and utilizes Uniform Luminance to prevent sudden aggressive dimming in areas of the screen. MSI has included OLED Care 3.0, which uses real-time detection for waking up the display, adaptive dimming, auto brightness, and color temperature control. Connectivity via DP 1.4a (HBR3) and 2x HDMI 2.1 for up to 4K 240 Hz is provided. A USB Type-C port supports DP Alt Mode with 15W PD.
MPG 322UR QD-OLED X24
“The MPG 322UR QD-OLED X24 features a 31.5-inch UHD (3840 x 2160) QD-OLED panel, 240Hz refresh rate, and 0.03ms (GtG) response time. Its 4th-gen Tandem QD-OLED panel utilizes EL Gen 3 technology to deliver vivid colors and better light efficiency. “
-MSI
Next, we have the premium MPG 322-UR QD-OLED, also 4th-Gen tandem with very similar specifications, but connectivity is provided via DP 2.1a at full bandwidth 80 Gbps (UHBR20), providing support for up to 4K 240 Hz (DSC) with DSR and DLDSR functionality. A USB Type-C port provides DP Alt mode and 98W PD features.
Discussion (5 replies)
Join Discussion →New gaming monitors you can't afford to drive. Nice.
Remember the 8K monitors AMD hyped up at RDNA3 launch?
I totally forgot about those but do regularly think about the failed 8K television launches.
Do these use the new RGB Stripe subpixel layout? I wouldn't even get an OLED today unless it had this new technology, since productivity is important in my workload.
I noticed it said 4th Gen OLED, I wasn't sure if that automatically means it uses the new layout or not.
Those are excruciatingly rare, unfortunately. I assume that they weren't made that way from the gorram beginning because it's hard to pull off with current OLED tech, and comes with disadvantages probably in terms of the brightness vs. panel life / burn-in tradeoff.
For now, the best bet is to just get something that you're going to run at 150% scaling, which fixes the text problem for the vast majority. I'm looking at LGs new 5k2k panel in 39", once Dell puts it in an Alienware (LGs monitor support and Q/C is laughable except when compared to the likes of Samsung and ASUS).
