XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition Video Card Review
Today, AMD is launching the AMD Radeon RX 9070 GRE to the US and global markets for $549. The Radeon RX 9070 GRE was originally launched as a China-exclusive video card in May of 2025. Now, the Radeon RX 9070 GRE will be more accessible to gamers. The Radeon RX 9070 GRE is aimed at the 1440p gaming experience, and combined with FSR 4.1 support, can support modern games, including Ray Tracing.
The Radeon RX 9070 GRE is a partner-driven video card, and therefore will only have AIB custom video card options. However, you will find entry-level models without factory overclocks that will be around the MSRP pricing of $549. There will also be factory overclocked video cards, some with higher power limits to allow higher factory overclocks, that come in at a price premium with some robust cooling options and designs.
The Radeon RX 9070 GRE sits closer to the Radeon RX 9070 on the scale of GPUs, rather than the Radeon RX 9060 XT. The Radeon RX 9070 GRE is a cut-down Navi 48 die that the Radeon RX 9070 uses, and also has a cut-down memory bus and capacity. The Radeon RX 9070 GRE consists of 48 Compute Units, 3,072 Shading Units, 48 RT Accelerators, 96 HW AI Accelerators, 96 ROPS, and 192 TMUS. It has a Game Clock of 2220MHz and a Boost Clock of up to 2.79GHz. It has 12GB of GDDR6 on a 192-bit memory bus, at 18Gbps, providing 432GB/s of memory bandwidth. The Total Board Power is 220W, and it does support PCI-Express 5.0 x16 full bandwidth.
Performance
In our review today, we took a look specifically at the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition video card. This is a custom video card with custom cooling, but it does not have a factory overclock; it runs at the AMD default of 2.79GHz Boost Clock, with 12GB of GDDR6. In our game testing today we took 13 games for a spin, and tested at the 1440p resolution at both Native Resolution and with FSR 4 Upscaling enabled, we also tested optional Ray Tracing performance in games as well.
Please refer to the game pages to see the actual percentage of uplift over the Radeon RX 9060 XT and how the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition compares to the Radeon RX 9070 and GeForce RTX 5060 Ti. We are going to simply sum up our experiences from gaming on the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition here.
Overall, the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition sits closer to the Radeon RX 9070 in performance than it does to the Radeon RX 9060 XT. You may think that the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition would be exactly between the Radeon RX 9060 XT and Radeon RX 9070. However, in some situations, it is a ‘middling’ performance, but more often than not, the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition hangs closer to the Radeon RX 9070 in performance that it provides.
We especially noticed that the Ray Tracing performance, or performance in ‘baked in’ ray-traced games, was much superior on the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition compared to the Radeon RX 9060 XT. In other words, the Radeon RX 9070 GRE is much stronger for Ray Tracing than the Radeon RX 9060 XT is.
The Upscaling performance also greatly helps the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition. Since RDNA 4 (Radeon RX 9070 GRE) supports FSR 4 and 4.1, we were able to utilize it at 1440p and gain the performance we needed in the most demanding games. We can enable “Quality” Upscaling at 1440p, and with FSR 4/4.1 the image quality is more than acceptable at that resolution. It allows us to achieve the performance we need in the demanding titles. In addition, “Balanced” also looks very good at 1440p with FSR 4/4.1, and that mode, combined with some Ray Tracing, actually provides a playable experience at 1440p in many games on the Radeon RX 9070 GRE.
Compared to the GeForce RTX 5060 Ti, the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition is a real winner. It is clear that the Radeon RX 9070 GRE is a big step up in performance compared to the GeForce RTX 5060 Ti 16GB. Remember, we WERE using the 16GB RTX 5060 Ti variant, and the Radeon RX 9070 GRE even with just 12GB was faster, and better for the gaming experience at 1440p Native Res or with Upscaling. Heck, the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition even beat the GeForce RTX 5060 Ti in Ray Tracing Performance!
Value, value is everything. It is clear from our testing that the Radeon RX 9070 GRE is a better value all-around compared to the similarly priced GeForce RTX 5060 Ti 16GB video card. At $549, the Radeon RX 9070 GRE matches or bests the current online pricing of the GeForce RTX 5060 Ti 16GB, which you can actually buy it for today. Current in-stock GeForce RTX 5060 Ti 16GB video cards START AT $559 (with sales), and primarily range around $580 and upwards right now, online. At $549, the Radeon RX 9070 GRE trounces that pricing and performance value, offering a lot more performance in every which way.
Now, the real question about the Radeon RX 9070 GRE is if it really will be $549, or thereabouts, or if prices will be inflated. The Radeon RX 9070 surely was, and is, inflated well beyond MSRP currently. So it will have to be seen if the Radeon RX 9070 GRE can maintain good pricing, or not. At any rate, even if it were around $580 (same pricing as RTX 5060 Ti), it would still be the better purchase simply because it is much faster.
Will the 12GB VRAM capacity hinder the Radeon RX 9070 GRE? I would say, eventually, yes, but it isn’t so much of a big issue right now, considering it is geared as a 1440p gaming experience video card, and that you can enable FSR 4/4.1 Upscaling, plus turn down game settings if you run into issues. It is clear that right now, the difference between 16GB on the RX 9060 XT or 16GB on the RTX 5060 Ti is not providing an advantage over the 12GB Radeon RX 9070 GRE in gaming right now. The Radeon RX 9070 GRE was still faster, even with Ray Tracing enabled, which typically eats into VRAM. I wouldn’t let the VRAM capacity of this video card hold you back from getting a good value in terms of performance per dollar.
As for the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition itself, this is a solid video card from XFX as we have come to expect. It is built well, though a bit bulky, and will look good in your build. We are slightly concerned about the Hot Spot temperatures, but otherwise, the cooling seems adequate overall. There isn’t much overclocking potential, but that is mainly down to the power targets and available power caps of the GPU and card itself, most likely imposed by AMD. If the XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition can be kept around or at MSRP levels, it will be a good purchase for gaming at this price point.
The FPS Review Score
The XFX Swift Radeon RX 9070 GRE Triple Fan Gaming Edition offers a great gaming experience at 1440p Native Resolution and with FSR 4 and FSR 4.1 Upscaling, and also does well with Ray Tracing. Compared to the GeForce RTX 5060 Ti 16GB it offers a great value in performance per dollar, and gives gamers a great option at this price range. It allows modern games to be played at high settings at Native Resolution or with FSR. It sits closer to Radeon RX 9070 performance than Radeon RX 9060 XT, and gives a great in-between option at $549.
