PowerColor has released its Liquid Devil AMD Radeon RX 6900 XT and Radeon RX 6800 XT graphics cards. Featuring a custom acrylic water block with RGB lighting, a nickel-plated copper base, and a nickel-plated finish made by EKWB, they are engineered for both performance and style. Power delivery is achieved through a 14+2 phase configuration with DrMOS and high polymer capacitors, which improve upon the 13 and 12 phase configurations found on the reference versions. The PCB and cooling solution is rated for up to 400 watts of power and includes a BIOS OC/Unleash switch for achieving higher clock speeds. They also come with a dye pack made by EK-CryoFuel for those seeking to customize their rigs even further. Prices have not been announced, but they are expected to be available on March 15.
Specifications
| Graphic Engine | AXRX 6900XT 16GBD6-W2DHC/OC | AXRX 6800XT 16GBD6-W2DHC/OC |
| Video Memory | 16 GB GDDR 6 | 16 GB GDDR6 |
| Stream Processor | 5120 Units | 4608 Units |
| Engine Clock | Game 2135 Mhz/ Boost 2365 MHz | Game 2110 Mhz/ Boost 2360 MHz |
| Memory Clock | 16.0 Gbps | 16.0 Gbps |
| Memory Interface | 256-bit | 256-bit |
| Bus Standard | PCIE 4.0 | PCIE 4.0 |
| Display Connectors | 1 x HDMI 2.1 , 2 x DisplayPort 1.4, 1 x USB-C | 1 x HDMI 2.1 , 2 x DisplayPort 1.4, 1 x USB-C |
| Form Factor | ATX | ATX |
| Cooler | EK water block | EK water block |
| Power Connector | 3 x 8-pin | 3 x 8-pin |
| OpenGL | 4.6 | 4.6 |
| DirectX® Support | 12 | 12 |
| Minimum System Power | 900W | 900W |
| Card Dimension(mm) | 266mm*162mm*42 mm | 266mm*162mm*42 mm |
