After years of requests, NZXT has finally released its first AMD motherboard, the N7 B550. The N7 B550 is a clean-looking piece of hardware that’s compatible with AMD Ryzen processors (3000, 4000, 5000 Series) and includes features such as digital RGB lighting and fan control that can be adjusted via the manufacturer’s PC monitoring software, NZXT CAM. NZXT’s N7 B550 motherboard also incorporates WiFi 6E connectivity and an efficient layout for streamlined installation.
“Designed around AMD’s latest chipset, the N7 B550 delivers everything you need to build an incredible gaming PC,” NZXT wrote in a press release. “Featuring built-in WiFi and Bluetooth, an integrated fan controller, and enough USB ports to add as much RGB as your heart desires – the N7 B550 is built for builders.”
“In addition to smart controls and making building easier, the N7 B550 also features the same clean aesthetic you’ll find in every NZXT product. The elegant metal cover blends seamlessly into your case and effortlessly brings out the beauty of your computer. Those of you looking to create a clean build that grabs people’s attention–look no further!”
NZXT’s N7 B550 motherboard is available now through the NZXT store for $229.99. Now that the manufacturer has pledged its support for red team, additional AMD motherboards are presumably on the way.
We heard you loud and clear!
— NZXT (@NZXT) March 25, 2021
Introducing the N7 B550 @AMD Motherboard!
🙉 https://t.co/zGgtwMM2OS pic.twitter.com/L6ffeg8KLY
