v-color Skywalker Plus DDR4 64GB (2x32GB) 4000MHz Memory Review
Skywalker Plus DDR4 64GB (2x32GB) 4000MHz Memory banner image
v-color is a memory and SSD manufacturer that has been at it since 2006. They currently offer a full line of DDR4 and DDR5 memory aimed at gamers at various clock speeds and in many cases, blinged out with RGB lighting on the memory.
The specific kit that we’re looking at today is the Skywalker Plus DDR4 64GB (2x32GB) 4000MHz memory kit which stands in the middle of the Skywalker Plus 64GB stack that has offerings as low as 3200MHz and as high as 4400MHz. The kits are offered in both a silver/mirrored finish and gold finish and come sans RGB bling. At the time of publication, v-color was offering this kit for $239.99 on its website.
The Skywalker Plus DDR4 64GB (2x32GB) 4000MHz Memory comes in a black circuit board patterned box with RGB highlights along the bottom and the notation of Skywalker Plus branding along with its total size. On the back, the v-color provides the speed, timings, serial number, and a bit about itself.
Inside the packaging, we found two 32GB modules etched with the part number TO432G40D818CSPSXK and the serial number bar code taped to the other side. The modules are clad in a silver heat spreader making a V shape in the middle that is mirror polished to the extent it’s near impossible to even see the part number etching. In fact, it’s so well polished that it is near impossible to photograph, which may explain why it looks a bit photoshopped on v-color’s site. The top of the memory sports a black circuit board-like pattern, not dissimilar from the box front. Unlike the branding on the box, the memory sticks do not have RGB lighting as part of its offering.
The kits sport Hynix memory modules that are set at PC4-32000 (4000MHz) at timings of 18-22-22-42 at 1.4V.
From a sizing perspective, the Skywalker Plus DDR4 64GB (2x32GB) 4000MHz Memory measures in at 1.5” in height, which is more or less a regulation height for memory. We would not expect any clearance issues for those big tower coolers that you love to use.
