MSI MPG A1000G/A850G/A750G PCIE5 Power Supplies
MSI MPG A1000G PCIE5 Power Supply
Note that we will not be powering on the MSI MPG A1000G PCIE5 power supply in this article.  We have yet to review and test the power supply (check out our PSU reviews), we have to run it through its paces in our validation testing using industry-standard PSU testing hardware to verify its integrity based on ATX standards.  We do not power on any power supply until it goes through our full review process.  Stay tuned in the future for a full review of the power supply and see if this one holds up.
The box is a slick black and purple color scheme, with the PSU pictured on the outside.  On the front is described the model, how many Watts, and the major new features.  On the backside it details the features, cables included and specific power and amperage information.  Inside the box is the power supply protected by foam, and all your cables are inside a very thick and protective case holder to keep all your cables you do not use in.
All the cables are shown above, as this is a fully modular power supply.  You can see the new 16-pin 12VHPWR cable included, both ends are full 16-pin with power and data sense.  On the cable, it indicates that this one cable supports 600W.  As per the new ATX 3.0 specification manufacturers must print the Wattage that the cable supports on the connector like this.  In this way, you can easily know how much power it can provide, as there is a scale between 150W to 600W maximum.  The ATX 3.0 spec specifies what Wattage of power supplies can supply what Wattage of 12VHPWR.
As you can see, the MPG A1000G PCIE5 is indeed compact, measuring only 5.9 inches in length and 3.4 inches in height.  It has a matte black finish, with silver accent on the sides and fan cutouts.  The fan is a large 135mm fan, which ultimately will mean a lower noise level even ramped up.  There is a button on the back that can turn the 0 RPM fan feature on or off.
The 12VHPWR connector plugs in with the data sense pins on the bottom, and the clip right side up.  It’s the same on both ends, and greatly reduces the number of PCIe cables needed on the GeForce RTX 30 Series.
Above we have a GeForce RTX 3090 Ti to demonstrate the new 16-pin 12VHPWR cable being plugged into it.  The GeForce RTX 30 Series does use the 16-pin connector, 12-pins for power, and 4-pins for data sense.  The new 16-pin 12VHPWR PCIe 5.0 cable on this power supply easily plugs into the GeForce RTX 3090 Ti, and would fully power it since the TDP of the video card is 450W.  The cable can support 600W to the GPU, so it is ready for next-gen parts.  This one cable greatly reduces the 3x 8-pin PCIe dongle needed for the RTX 3090 and RTX 3090 Ti.
As we mentioned at the top of this page, we have not powered on the power supply as of yet. We must validate and test the power supply for our official review. Therefore we cannot verify the claims of the power supply currently, we cannot verify how good this power supply actually is and if it performs as advertised. Stay tuned for our full review.
In the meantime, we did take a look at the MSI MPG A1000G PCIE5 today with pictures and detailed specifications offered. It will have an MSRP of $199.99 and you can check out the MSI store page at that link. The new MPG line of PSUs, MPG A1000G PCIE5, MPG A850G PCIE5, and MPG A750G PCIE5 are being launched today from MSI and bring forth ATX 3.0 compatibility and PCIE5 full 16-pin 12VHPWR connector and power cable up to 600W. In addition, the power supply is quoted to handle power excursions exhibited by GPUs as per the ATX 3.0 and PCIE5 CEM spec.
MSI MPG A850G PCIE 5 & ATX 3.0 Gaming Power Supply - Full Modular - 80 Plus Gold Certified 850W - 100% Japanese 105°C Capacitors - Compact Size - ATX PSU
$134.99
in stock
MSI - MPG A850G PCIE 5.0, 80 GOLD Full Modular Gaming PSU, 12VHPWR Cable, 4080 4070 ATX 3.0 Compatible, 850W Power Supply
$159.99
in stock
MSI - MPG A1000G PCIE 5.0, 80 GOLD Full Modular Gaming PSU, 12VHPWR Cable, 4080 4090 ATX 3.0 Compatible, 1000W Power Supply
$199.99
MSI MPG A1000G PCIE 5 & ATX 3.0 Gaming Power Supply - Full Modular - 80 Plus Gold Certified 1000W - 100% Japanese 105°C Capacitors - Compact Size - ATX PSU
out of stock
Power excursions have been important in the past, and generally, the only way to combat it was by buying higher capacity PSUs that have a higher overall TDP, and therefore a greater tolerance when it spikes. This problem of power excursions will continue to be important as rumors of next-gen GPUs may consume much higher TDPs. With high TDPs come high excursions, remember, upwards of 3x the TDP for microseconds. It will be important for your power supply to be able to handle this, and not choke or explode when this happens. In addition, CPUs also have increasing power excursions, with Intel CPUs already eating over 240W+ package power, and Zen 4 also increasing its TDP on high-end parts. The need for a good quality power supply that can handle not only appropriate Wattage, but these excursions, will be very important.
Lastly, the fact of being able to reduce PCIe graphics cables is a huge bonus, we were simply being overrun with 8-pin power cables previously. A new cable, a new standard, and more power delivery with fewer cables were most certainly needed. MSI will also not be the only manufacturer with ATX 3.0 and PCIE5 PSUs, expect the flood of this new type of evolved PSU to start, this is the season for these new power supplies.
Discussion (19 replies)
LazyGamer
LazyGamer 👍 1
Alright, countdown to NA availability!
Brent_Justice
Brent_Justice 👍 1
I updated the pricing info for A1000G PCIE5 in the review, and here is the link to The Official U.S Online Store for MSI where it is in stock.
https://us-store.msi.com/MPG-A1000G-PCIE5
LazyGamer
LazyGamer 👍 1
Man, at US$200 for a new-spec 1000W PSU?
That's not even offensive, and approaching affordable.
Yep, almost makes me want to order one even though I don't really need one yet.
Peter_Brosdahl 👍 1
Thanks, @Brent_Justice for all these intro-breakdowns of new tech and architectures. There's a lot happening these days and it's nice having a quick resource to go back to and refresh with before making a purchase decision.
xGryfter
xGryfter 👍 1
Almost a month later and still no sign of these. Has MSI given any word on when we'll start seeing these in stores?
Niner51
With a 4090 on the way and no word from EVGA on a cable (possibly cablemod?) I was thinking about another PSU myself, but no word on availability. You would think these would be available once the new video cards hit the market.
Yes thst kinda annoys me to. I sent a duppprt request in a d got back. Use the adaptor.
Brian_B 👍 2
Whatever keyboard you are using, you should douse it in fire. That, or maybe we should call 911, you may be having a stroke.
Space_Ranger
Space_Ranger 👍 1
1000W models are going to become the BASELINE model in a couple of years.. Calling it now...
LazyGamer
We're already more or less there; take the power limits off an i7 or R7 and a top-end GPU and you're already at 700W before the rest of the system.
This means that 850W is just enough, which to most of us means get the next highest capacity unit.
I'd only be comfortable with 850W or lower if power limits were planned in to the build.
Niner51
The 1000w version of this PSU is selling ridiculously quick. I thought about getting one a few times, but I'd be pushing it with my current system. Price gouging is definitely not reserved for just GPU's this time. Too bad the higher wattage variants aren't available at all right now.
Peter_Brosdahl 👍 1
Remember when PSUs were that part that so many didn't pay attention to beyond a certain wattage or energy rating? Now with ATX 3.0 they've become the latest hot-ticket item. I, and others, noticed that one of those 4090 reports was from someone who managed to snag a 1300W MSI somehow, in China.
Niner51
Niner51 👍 2
All these people grabbing these 1000W ATX 3.0 power supplies may regret it later on if they throw in a 4090 with their other high end components. I did many of calculators on my main system, and it was around 930 to 950W, but having the headroom is always best practice.
I totally agree. I feel I'm at the edge of the comfort zone with the 1000W one I have with my 5800X3D/3090 Ti. I want to drop a 1200-1300W in there when I can. My other rig has a 1200W (from the days when I ran 2-3 GPUs) but both are ATX 2.0.
