MSI Announces MAG X670E TOMAHAWK WIFI Motherboard
Image: MSI
MSI has announced the MAG X670E TOMAHAWK WIFI, a new AM5 motherboard that will feature full support for all AMD Ryzen 7000 Series processors at launch, including the newly released Ryzen 9 7950X3D and Ryzen 9 7900X3D CPUs with 3D V-Cache. As fans of the popular TOMAHAWK series might expect, the new motherboard is inspired by the military concept, crafted in a design that serves as a symbol of robustness and durability that the manufacturer says allows users to have the optimal experience. MSI did not confirm pricing or dates of availability in its press release.
MAG X670E TOMAHAWK WIFI Data Sheet
From an MSI press release:
The MAG X670E TOMAHAWK WIFI features a 14+2+1 Duet Rail Power System (DRPS) with 80A SPS power phase and 8-layer PCB with 2oz thickened copper which delivers stable currents to the processors. To deal with the heat that is generated from the motherboard, the MAG Series features a premium thermal solution with an Extended Heatsink to ensure that all the components run stable through intensive workloads.
When it comes to expansion, the MAG X670E TOMAHAWK WIFI supports DDR5 memory with AMD Certified EXPO profiles in the BIOS for an extra performance boost and supports fast Lightning Gen 5.0 PCIe slot. There are 4 M.2 slots onboard which the first M.2 slot supports Lightning Gen 5 with double-sided Shield Frozr while the rest are Lightning Gen 4.0 for onboard storage which the M.2 Shield Frozr will cover the 2nd and 3rd slot of the M.2 connectors.
With all the lightning-fast storage, connectivity is just as important to transfer data as fast as possible and enjoy an instantaneous networking experience without any bottlenecks, which is why the MAG X670E TOMAHAWK WIFI will come with 2.5G LAN, Wi-Fi 6E, and Bluetooth 5.3. Regardless of what you do, it will blaze through any games and applications you throw at it, and won’t be disappointed.
