MSI Z790-P PRO WiFi Motherboard Review
Test Setup
Unfortunately, the Core i9 12900K we used for testing isn’t much of an overclocker. To that end, we have run the benchmarks on default Intel power limits of 241w and the motherboard defaults which are controlled by the motherboard’s automatic settings. The latter of which is how most motherboards operate out of the box.
Note: Memory for DDR5 motherboards will now be DDR5 6000MHz, as a result, older results will lag the current test platforms. However, going forward this will be the standard for DDR5 while DDR4 is going up to DDR4 3600MHz.
6
Motherboard Layout
Performance & Stability
Price Value
7
The MSI Z790-P PRO WIFI has a good layout, excellent stability, awesome performance but unfortunately falls victim to some cost cutting when it comes to features. The HD audio CODEC is ancient, you have no optical output and the network controller isn't fantastic. However, these issues may not be a deal breaker if you are going wireless or are using a USB DAC or headphones. At the end of the day, the MSI Z790-P PRO WiFi is what you'd expect in this price point.
Discussion (7 replies)
h
Intel's i225v & i226v have proven to be junk that should be avoided. Intel is probably giving them away. Any manufacturer using them should be called out.
Yea I wouldn't get another pro series from MSI. I had the x570 pro-a. Was always solid but I always worried about the caps.
Space_Ranger
Space_Ranger
Just curious (as I haven't been looking for a little while now), but what Networking Controller would you trust if the i225v and i226v's are junk?
Thanks @Dan_D for the awesome review.
I took a chance on not one but two Pro Series motherboards for a couple of my rigs and so far they've done well. Quite frankly I was on a tight budget in upgrading two rigs right after each other so I was looking for the cheapest motherboard I could find with the features I was after. I don't know if they've got the Intel NIC chipset or not but one is plugged in while the other is using Wifi and both have done well with transfer speeds but I'm not constantly having to push either except for game downloads.
I have been a little worried about power but they seem to be doing alright with the 5800X3D. According to MS AB, it mostly averages around 50-60W and occasionally jumps to ~85W during heavy loads but so far, so good.
LazyGamer
LazyGamer 👍 1
I've had an on-again off-again experience with them. I've found that if they're acting up, the interface can be popped and they come back to life.
I feel that it's a driver / firmware issue; it's certainly not expected for Intel to fumble NICs, as they're sort of the consumer / prosumer / entry enterprise option of choice. Their WiFi modules are still stellar, from what I've seen hands on.
From what I can tell, the i225v / i226v work pretty well under Linux too.
As a rule, AM4 boards were all questionable. Some X370 boards were rock solid, some X570 boards weren't. Brand and tier irrespective.
With LGA1700 and AM5, both Intel and AMD asserted significant control as to the 'minimums' acceptable for boards sporting their halo chipset, I've observed. Unless you are truly scraping the bottom of the barrel, any Z or X board for the new sockets is good to go from a base functionality perspective.
US$200 and US$1200 boards will perform exactly the same for consumer usecases. You'd need to push into extreme OC of the CPU (i.e., sub-ambient using LN2 or water chilling), or trying to set memory overclock records with DDR5, in order to need a 'better' board.
Where boards differentiate mostly is in terms of features, with stuff like 10Gbit Ethernet, TB4 / USB4, post code readers, power and reset buttons, more controllers for fans and water pumps and temperature probes, etc. If you don't need any of that stuff, a 'Pro' board like this one is all you could ever need. Aesthetics aside, of course.
Mine are B550's, but so far they're doing well. If I remember correctly they came out after the 570's and perhaps some improvements were made despite being the lower tier. Seriously, plug and play with the 5800X3D. Didn't even have to update the firmware on the first power-ups for either and XMP was ready to go, just had to click on it in the BIOS. I paid $120 for each and I'm smiling over it.
LazyGamer
LazyGamer 👍 2
The B550 came later, and there was also an X570S that provided a lower-power update (and hopefully other fixes) to X570.
The bigger problem was just the inconsistency of the boards. Some were great, others not so much; we don't see that with AM5, thankfully.
Dan Dobrowolski
