ASRock Radeon RX 7600 XT Steel Legend 16GB OC Video Card Review
Test Setup
More information on our GPU testing can be found here.
We are using the motherboard’s current default BIOS settings on the latest official release BIOS.  We have enabled PCI-Express Resizable BAR in the motherboard BIOS.  This means we are utilizing Resizable BAR on NVIDIA GPUs and AMD Smart Access Memory on AMD GPUs in all of our testing.  We have enabled DOCP in the BIOS for the memory. We are using a fresh install of Windows 11 Pro with the latest Windows Updates, and drivers installed including the latest chipset drivers from AMD.  We are using the “Best Performance” power profile in Windows Settings.  We have hardware-accelerated GPU Scheduling at the default setting, which is ENABLED.  VBS is DISABLED and Game Mode is ENABLED.
Gaming Performance
Build Quality and Cooling
Overclocking
Price and value
This review evaluates the newest release from AMD RX 7000 series, the ASRock Radeon RX 7600 XT Steel Legend 16GB OC. This video card has an interesting white and gray aesthetic and clear RGB fans. It looks and feels well built. It is very quiet and cool even when robustly overclocked. When overclocked we see improved performance over the GIGABYTE Radeon RX 7600 Gaming OC and GIGABYTE GeForce RTX 4060 OC Low Profile. This card does struggle in Ray Tracing capability however. The performance does vary when compared to the Radeon RX 7600. The performance to cost margin may not be wide enough for some buyers despite the extra VRAM included on the ASRock Radeon RX 7600 XT Steel Legend 16GB OC. The future may hold games which will leverage more VRAM and that is the distinction with this card. That may give it more utility. All in all, this is a sound video card in this price and performance tier and it has distinct good looks. It overclocks well. The ASRock Radeon RX 7600 XT Steel Legend 16GB OC is certainly worth consideration.
