You can never have enough RGB, or can you? Well, regardless, MSI has got you covered by adding RGB to a relatively overlooked piece of display hardware, the monitor arm. The MSI MPG MT201RG (for single displays) and MPG MT201DRG (for dual-display setups) feature RGB illuminated strips and an MSI logo for that added personal touch.
Features:
- Screen Size Compatibility – Supports flat or curved screens up to 49 inches in size.
- Weight Capacity – Features a built-in spring tension mechanism capable of holding monitors up to 20 kg / 44 lbs (per screen).
- VESA Compatible – Fits most monitors with the VESA compatibility of 75×75 / 100×100 mm.
- Gas Spring – Offers higher screen size support and effortless adjustability with the gas spring design.
- Full-Motion – Offers full motion for customizable viewing angles tailored to your everyday use.
- Easy Installation – Tool-free monitor arms for hassle-free installation or seamless grommet mounting.
- Cable Management – Keeps your wires organized and out of sight for an orderly desk.
- RGB LED – Dazzles your gaming setup with 20 dynamic RGB LED modes for an immersive experience.
- VESA Quick Release – Features a quick installation/release to ensure minimal downtime and maximum productivity.
Product Specifications:
MOUNT TYPE: Table Mount
VESA COMPATIBILITY 75 x 75 mm – 100 x 100 mm
Screen Size 17” ~ 49”
MAX WEIGHT CAPACITY 2 ~ 20 kg / 4.4 ~ 44 lbs
Grommet Installation Yes
CLAMP INSTALLATION Yes
DESK THICKNESS Maximum 10 ~ 85 mm (Clamp)
Maximum 10 ~ 48 mm (Grommet)
COLOR Matte Black & Dark Grey
ADJUSTMENT (TILT) -20° ~ 50°
ADJUSTMENT (SWIVEL) -90° ~ 90°
ADJUSTMENT (PIVOT) -180° ~ 180°
MAX EXTENSION (VERTICAL) 500 mm (19.69 inch)
MAX EXTENSION (HORIZONTAL) 542 mm (21.34 inch)
WEIGHT (NW / GW) 4.88 kg (10.76 lbs) / 6.3 kg (13.89 lbs)
DIMENSION (W X H X D) 138 x 659 x 553 mm (5.43 x 25.94 x
21.77 inch)
CARTON DIMENSION (W X H X D) 481 x 121 x 324 mm (18.94 x 4.76 x
12.76 inches)
MPG MT201DRG
The MSI MPG MT201DRG supports dual display setups with screen sizes up to 35″ and otherwise has identical features to its single display counterpart.
Neither product is yet available in North America, but MSI has launched product pages for both in Europe. The MSI MPG MT201RG is available for £89, and the MPG MT201DRG goes for £149.
Discussion (2 replies)
Join Discussion →Are you &*$)ing kidding me?!
I mean WTF not... Corsair has RGB Headset hangers... so why not RGB monitor arms... I mean heck... that's what most people see physically while watching a gaming tournament in person. Bunch of monitor arms. Why not get some branding and LED strips going. Better yet... Scrolling animated messages so you can have branding on the fly!
Scary but true
