SilverStone Nightjar NJ700 700W Fanless Power Supply Review
Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the SilverStone NJ700 at 45c. This makes Test #1 equal to 185W by loading the 12v rail to 13a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~330mV drop on the 12v rail and ~50mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~40mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the SilverStone NJ700 at 45c. This makes Test #2 equal to 327W by loading the 12v rail to 24a, the 5v rail to 3a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~340mV drop on the 12v rail and ~100mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~50mV drop.
The Transient Load Tests results for the SilverStone NJ700 are passing and generally good. In today’s testing, the NJ700 saw the loaded 12v rail post a peak change of ~340mV, and the loaded 5v rail post a peak change of ~100mV. The unloaded 5v peak change during the 12v load was ~50mV. Those numbers are, in an absolute sense, decent to generally good. In a relative sense, when we consider that this unit is a fanless product, they are good as well. Indeed, they were mixed with the Antec NEO ECO GOLD ZEN 700W and Cougar BXM 700. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
Paul Johnson
