Patriot Viper Venom RGB DDR5 32GB (2x16GB) 6200MHz Memory Kit Review
1080p Gaming Benchmarks
To start the gaming testing, we will run benchmarks at the 1080p resolution which makes the games selected very much CPU bound from a performance perspective (as we have an RTX 3090 as the test bench card today). This resolution should allow seeing what, if any, differences can be seen between the memory speeds when the CPU is the limiting factor on performance.
Shadow of the Tomb Raider
Patriot Viper Venom RGB DDR5 32GB (2x16GB) 6200MHz Memory Kit 1080p Shadow of the Tomb Raider performance
Starting off with Shadow of the Tomb Raider, we find the Viper 6200MHz memory out on top of the Corsair 5600MHz by 3FPS which is 3FPS faster than the 4800MHz memory. When 3FPS is the difference, we’re talking under a 1.5% performance difference overall.
Horizon Zero Dawn
Patriot Viper Venom RGB DDR5 32GB (2x16GB) 6200MHz Memory Kit 1080p Horizon Zero Dawn performance
Next up with Horizon Zero Dawn, the Viper 6200MHz prevails once again but this time by a margin of 4FPS over the Corsair 5600MHz. The 4800MHz memory picks up the rear by a single FPS. Again, we’re not talking about a material difference in this game between the entrants.
Watch Dogs: Legion
Patriot Viper Venom RGB DDR5 32GB (2x16GB) 6200MHz Memory Kit 1080p Watch Dogs Legion performance
Loading up Watch Dogs Legion, we find the Viper 6200MHz out front by a single FPS over the Corsair 5600MHz which was two faster than the 4800MHz memory. Again, this is more of an academic difference to examine than a real-world one.
Ghost Recon: Breakpoint
Patriot Viper Venom RGB DDR5 32GB (2x16GB) 6200MHz Memory Kit 1080p Ghost Recon:Breakpoint performance
In Ghost Recon: Breakpoint, the Viper 6200MHz tied with the 4800MHz memory who both beat the Corsair 5600MHz memory by 1FPS. I’ll let the reader complete the next sentence in their head about how much of a difference it made. (Ed: You forgot to leave a blank line for them to complete it!)
4K Gaming
For our second round of gaming testing, we will put our pinkies out and we will run benchmarks at the 4K resolution which makes the games selected very much GPU bound from a performance perspective (as we have an RTX 3090 as the test bench card today). This resolution should allow seeing what, if any, differences can be seen between the memory speeds when the GPU is the limiting factor on performance.
Patriot Viper Venom RGB DDR5 32GB (2x16GB) 6200MHz Memory Kit 4K Shadow of the Tomb Raider performance
Now things start to get a bit more interesting at 4k with Shadow of the Tomb Raider. We find the Viper 6200MHz memory out in front of the 4800MHz memory by 4FPS and 5FPS ahead of the Corsair 5600MHz. This is a 5.6% spread, which is the most significant that we’ve seen in a gaming scenario so far.
Horizon Zero Dawn
Patriot Viper Venom RGB DDR5 32GB (2x16GB) 6200MHz Memory Kit 4K Horizon Zero Dawn performance
While the last game got our hopes up, Horizon Zero Dawn brings us back to reality with a virtual tie across the board at 4K.
Watch Dogs: Legion
Patriot Viper Venom RGB DDR5 32GB (2x16GB) 6200MHz Memory Kit 4K Watch Dogs Legion performance
Watch Dogs Legion could not be one-upped by the last game, so it made sure that all memory flavors landed in a draw at 62FPS.
Patriot Viper Venom RGB DDR5 32GB (2x16GB) 6200MHz Memory Kit 4K Ghost Recon: Breakpoint performance
Finally with Ghost Recon: Breakpoint, we see a rounding error (of 1 FPS) between the top-performing Viper 6200MHz memory and the 4800MHz memory.
