GIGABYTE GeForce RTX 4070 Ti SUPER WINDFORCE OC 16GB GPU Review
Test Setup
More information on our GPU testing can be found here.
We are using the motherboard’s current default BIOS settings on the latest official release BIOS.  We have enabled PCI-Express Resizable BAR in the motherboard BIOS.  This means we are utilizing Resizable BAR on NVIDIA GPUs and AMD Smart Access Memory on AMD GPUs in all of our testing.  We have enabled DOCP in the BIOS for the memory. We are using a fresh install of Windows 11 Pro with the latest Windows Updates, and drivers installed including the latest chipset drivers from AMD.  We are using the “Best Performance” power profile in Windows Settings.  We have hardware-accelerated GPU Scheduling at the default setting, which is ENABLED.  VBS is DISABLED and Game Mode is ENABLED.
Gaming Performance
Build Quality and Cooling
Overclocking
Price and value
This is a review of the GIGABYTE GeForce RTX 4070 Ti SUPER WINDFORCE OC 16GB video card. The review evaluated performance at 1440p and 4K with and without ray tracing. We also overclocked the video card. This is a very well built and designed card. It represents the lowest tier in the RTX 4070 Ti SUPER offerings from GIGABYTE but is very capable and uniquely designed. There is a 6% uplift from the plain RTX 4070 Ti and also more video memory for the same $799 price. This video card is very much worth consideration if you are seeking an enthusiast class video card.
