Phantom Blade Zero Performance & IQ Review
Phantom Blade Zero is a brand new game from S-GAME and S-GAME Studios, based on Unreal Engine 5. This is a single-player role-playing style game. NVIDIA has worked with S-GAME to bump this game up to Path Tracing using ReSTIR Global Illumination. Since it is based on Unreal Engine 5, it uses Nanite Geometry and Lumen Global Illumination by default.
This game features Ray Tracing, which adds Ray Traced Shadows and Ray Traced Reflections, but still uses Lumen GI. With Path Tracing, it goes the extra mile to add ReSTIR GI, taking the place of Lumen, and also providing Ray Traced Water Caustics. In addition, DLSS 4.5 is native in the game with Frame Generation and NVIDIA Reflex. The game also supports FSR 4.1 and AMD FSR Frame Generation. In our Performance and IQ Review, we took a look at some specific comparisons, including video card comparisons, ray tracing performance, frame generation performance, and image quality comparisons.
Ray Tracing & Path Tracing
While playing this game, we did find Path Tracing to improve the gameplay experience overall. In terms of visuals, Path Tracing is a big step up from running the game at its default settings with Lumen GI. It may be hard to tell from the small screenshots in this review, but when you are in the game, running it full-screen in your face, you can actually notice the differences. You can also see the differences between standard Ray Tracing and Path Tracing when you are playing it in front of your face, live, with it moving.
Standard Ray Tracing has the benefit of improving shadows and reflections. We noticed that shadows did look better, giving the game more depth and contrast. Reflections of objects and the environment in the water, for example, were also improved with standard Ray Tracing. However, you must also enable DLSS Ray Reconstruction with standard Ray Tracing.
This game’s default denoiser is quite bad; it is very grainy. With Ray Reconstruction, the game looks noticeably better. This is bad news for AMD since this game does not support AMD Ray Regeneration, and so with Ray Tracing AND Path Tracing, textures and surfaces are grainy on AMD GPUs. Standard Ray Tracing won’t improve Global Illumination; however, for that, you need to enable Path Tracing.
Path Tracing is really the way to go in this game. With Path Tracing enabled using ReSTIR GI instead of Lumen GI, you can notice the difference in image quality. We experienced even more improved contrast and shadowing, especially as you look into deep forested areas or deep foliage; the result can be quite dramatic. We even saw shadows being added that weren’t there before in standard Ray Tracing.
The Global Illumination lighting was also much better. We experienced improved colors and contrast, and you could actually see more depth between foreground and background objects. This was very noticeable when you had dark objects close to you with brighter objects in the background, or vise versa. You could also tell this indoors or in areas that have extreme lighting; there were darker areas with Path Tracing, as it should look.
Performance
In terms of performance, this game is demanding, but not as much as you might think with Ray Tracing or Path Tracing. We found that standard Ray Tracing generally caused about a 15% performance drop compared to without it. Then, further enabling Path Tracing was actually a rather small 6-7% drop in performance from standard Ray Tracing. This shows that ReSTIR GI is pretty efficient.
Now, when running Path Tracing, you are going to want to have DLSS Upscaling or FSR Upscaling enabled. It’s still enough of a performance hit that you need to claw that back with Upscaling. You will have to adjust the level depending on your desired performance. While we showed Quality mode, you can run in Balanced mode just fine in this game with great image quality thanks to DLSS 4.5 and FSR 4.1, or maybe even more aggressively at higher output resolutions.
We also found 2X Frame Generation to be quite acceptable in this game. Sometimes Frame Generation can make games feel laggy as it adds latency. However, for this particular game, we were a bit surprised how smooth it felt, even at lower base framerates. Generally, you want high base framerates to start with. For this game, it actually helped make lower performance settings feel more playable. For this style and type of game, Frame Generation, at least 2X, may be an option to smooth out gameplay. Just know that it isn’t a performance enhancer; it’s not improving performance, it’s a smoothing technology, but it does do it well in this game.
For midrange cards, your best bet is probably to forgo Path Tracing and just try to run at the “Ultra” quality preset at the highest possible resolution. If you enable DLSS Upscaling or FSR Upscaling, you’ll get very acceptable performance with this. Though, if you want to try to aim for the stars, go for it; try Path Tracing and a more aggressive form of Upscaling. I wouldn’t downgrade the graphics options, though, to do this. I’d rather turn off Path Tracing than lower the graphics options. I for sure would keep the graphics options at “High” or higher; “Medium” has too many compromises visually.
Summary, Thoughts & Opinions
Overall, it’s great to see a game embrace some of the latest technologies. Having DLSS 4.5 and FSR 4.1 baked into the game natively, with Frame Generation, DLSS Ray Reconstruction, and NVIDIA Reflex, is great to see. We need games to natively support these features, rather than having to rely on driver control panel overrides. This game also embraces Path Tracing and a better ReSTIR Global Illumination to improve the visual quality of the entire game, and it is transformative, in my opinion, for this game. I hope to see Path Tracing adopted more in games, and done efficiently. Typically it has been a large performance hurdle, but for this game at least, it seems to be done well; I want that trend to continue. I, in fact, don’t even see the need for the standard Ray Tracing option here. IMO, just have Path Tracing and be done with it. Well, that’s it, everyone. Happy Gaming!
