Image Quality – Ray Tracing vs Path Tracing
Now we are going to directly compare Ray Tracing vs Path Tracing. With Ray Tracing enabled we also have DLSS Ray Reconstruction enabled, with Path Tracing it is automatically enabled. Keep in mind that the big thing with Path Tracing is the use of ReSTIR Global Illumination, whereas just Ray Tracing uses Lumen Global Illumination. Path Tracing also adds water caustic effects. This page will be quite long, so be sure to scroll down to the end of the page so you don’t miss any of these comparisons. Use the slider to scroll the “Before” screenshot (Left) and “After” screenshot (Right).
In both screenshots, DLSS Upscaling: Quality is enabled, and Ray Reconstruction is enabled. The LEFT or BEFORE screenshot is with Ray Tracing, while the RIGHT or AFTER screenshot is with Path Tracing enabled.
(LEFT = RAY TRACING | RIGHT = PATH TRACING)
