Phantom Blade Zero Performance & IQ Review
Frame Generation Performance
On this page, we are going to compare Frame Generation performance and see what that adds to the whole experience. Keep in mind that Frame Generation is not actually performance in the traditional sense, but rather a frame smoothing technique. We will, however, report the framerate reported for AVG and 1% Lows. The GeForce RTX 50 Series is capable of Multi-Frame Generation up to 6X, as well as Dynamic, while AMD only supports Frame Gen ON, which is 2X. For the sake of testing scope, we will only test the RTX 5090 up to 6X; the others only at 2X.
NVIDIA GeForce RTX 5090
Phantom Blade Zero GeForce RTX 5090 Frame Generation Performance
When looking at Frame Generation, we might as well enable it with everything on, so Path Tracing is enabled here to compare results. When we enable DLSS Upscaling: Quality over TSR: Native, the improvement is 51%. When we turn on Path Tracing with DLSS Upscaling: Quality, performance drops by 35%. When we then turn on 2X Frame Generation, the framerate increases by 72% over Path Tracing with just DLSS Upscaling: Quality. When we turn on 4X Frame Generation, the framerate increases by 83% over 2X Frame Gen. Then when we turn on 6X Frame Generation, the framerate increases by 39% over 4X Frame Gen. All of the 1% Lows are above 60FPS with Frame Generation.
NVIDIA GeForce RTX 5080
Phantom Blade Zero GeForce RTX 5080 Frame Generation Performance
With the NVIDIA GeForce RTX 5080, turning on DLSS Upscaling: Quality improves performance by 47%. Turning on Path Tracing drops performance by 32%. Turning on 2X Frame Generation increases the framerate by 69%. Turning on 4X Frame Gen increases the framerate by 80%. Turning on 6X Frame Gen increases the framerate by 38%.
NVIDIA GeForce RTX 5070 Ti
Phantom Blade Zero GeForce RTX 5070 Ti Frame Generation Performance
Turning on DLSS Upscaling: Quality on the GeForce RTX 5070 Ti improves performance by 50%. Turning on Path Tracing with DLSS Upscaling: Quality drops performance by 33%. Turning on 2X Frame Generation increases the framerate by 69%, and 1% Lows are above 60FPS.
Phantom Blade Zero GeForce RTX 5070 Frame Generation Performance
Turning on DLSS Upscaling: Quality improves performance by 43%. Turning on Path Tracing drops performance by 30%. Turning on 2X Frame Generation increases the framerate by 73% and the 1% Lows are above 60FPS.
NVIDIA GeForce RTX 5060 Ti 8GB
Phantom Blade Zero GeForce RTX 5060 Ti 8GB Frame Generation Performance
Turning on DLSS Upscaling: Quality improves performance by 50%. Turning on Path Tracing drops performance by 33%. Turning on 2X Frame Generation increases framerate by 74%, and 1% Lows are above 60FPS.
Phantom Blade Zero GeForce RTX 5060 Frame Generation Performance
Turning on DLSS Upscaling: Quality improves performance by 51%. Enabling Path Tracing drops performance by 33%. Enabling 2X Frame Generation increases framerate by 72%, but the 1% Lows are not above 60FPS.
AMD Radeon RX 9070 XT
Phantom Blade Zero Radeon RX 9070 XT Frame Generation Performance
Yes, the AMD Radeon RX 9000 series can run Frame Generation in this game, natively supported in the game. When we enable FSR Upscaling: Quality, performance increases by 50%. This is really the only way to play the game well on the Radeon RX 9070 XT at 1440p. When we enable Path Tracing, the performance drops by 33% and is not playable. When turning on Frame Generation, the framerate increases by 96%, which is quite a bump in framerate; the 1% Lows also increase a large amount by 143%. The game does feel smoother with Frame Generation turned on with the Radeon RX 9070 XT using Path Tracing. This is a playable experience.
